A very low volume well , adding a storage tank (?) Novice!
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
It is usually easier to install the submersible from the top. I make a notch by the side of the manhole cover and either hang the pump from there or anchor the hose coming from the pump laying on the cistern floor with a flow sleeve and something to keep it a few inches off the bottom.
Work4latte
Washington state
ah , i wasn't clear about the blue 'bunch of old stuff' - i'm not touching it. the old pressure tank, filters, and all that are staying intact. there will be a way to send water directly to the house from there, bypassing the storage tank system completely. I've learned the hard way in my diy projects to always have an alternative... at least until things have run for a while and proven stable.
All that old stuff is in a pumphouse, that may well have to be taken down to work on the well - if (when) than happens, i can run the storage tank with trucked-in water and move all that mess at my leisure, to get to the wisely advised state of the well being isolated and completely accessible.
Work4latte
Washington state
in the picture of the pump on two pipes, there's no flow sleeve on the pump? the pump looks like it would sit flat on it's side and i thought i read that it should have the exit end elevated?
and you're just running the pipe up and out the tank hatch? Simple, i like that but there must be a union or something that allows you to disconnect and pull the pump?
Work4latte
Washington state
i like the simplicity of the pipe just going out the hatch, and not using a pitless, as i said above, but - how do you prevent the pipes from freezing? It doesn't get super cold here (pnw marine climate) but we can have up to a week of temps in the teens. I can tape and insulate the pipe once it's outside the tank, but what about the part sticking out of the water inside the tank? won't that freeze? (plastic tank above ground)
