5600SXT upflow?
Monet33
LA
Sorry for the noobie question but can 5600SXT be programmed to do upflow regeneration instead of downflow in settings?
It would need a different piston to do upflow brining. Probably a new injector. Then programming.
So in answer to your question, you cannot switch a downflow brining softener to upflow with just a setting.
Monet33
LA
so it's possible to order a different piston for upflow on the 5600SXT if they will do it? I see most go with downflow but was wondering why more people don't go with upflow piston if it save on water/salt
It is a small savings, and things can go wrong if the brine is injected fast enough to cause some resin to rise and to open a channel in the bed.
ditttohead
Water systems designer, R&D
Ontario California
I would not bother. It does not really save enough to be worth the potential problems. I do training on how great, or how bad upflow brining is depending on the marketing strategies of my customers. It is useful in a few applications but for 99%, downflow is typically preferred.
Monet33
LA
thanks, i've researching and it seems like downflow would be better route and easier to maintain. What do you think about the 5600sxt cabinet setup vs tank setup? Is one better than the other
