Help validating WS1EE settings
quito_mont
Bay Area, CA
Hi Everyone! I have recently gotten a new system and would like to get your help in getting feedback on the settings. Please let me know if anything looks off. Thanks in advance for your help.
Background Info
Source: City water.
Hardness: 20 grains per gallon
Daily usage is 120 gallons a day.
Stages
  1. Sediment filter is down to 5 micron.
  2. Activated carbon upflow filter with 1.5 cu ft tank and GAC / CS-HAC
  3. Softener has a WS1EE valve, using 1.5 cu ft tank, filled with Aldex 10% resin
What’s at the WS1EE valve:
Injector cap:
It has a E on the top for V3010-1E / white for the down 10”.
DLFC: V3162-027 for 2.7 gpm
Using Potassium in brine tank.
These are settings and feedback much appreciated!
System Setup
CategoryValue UsedComment
Brining DirectionDownAssumption: Downflow is more robust and upflow brining requires more precise setting
Refill PrEAssumption: Is 4 hours enough to dissolve potassium?
1 Backwash8m
2 Brine1h 10m
3 Backwash6m
4 Rinse7m
5 - pounds 8 lbs Based on 14 days x 2400 grains a day to replenish (33600 x 10-15% for potassium)
Capacity36.0 x 1000Is it ok to set this to lower than the actual number of resins in the tank, as my usage is low?
Volume Capacity / RegenAuto
Regeneration Time OptionNormal
RelayNot applicable
Installer Setting - Type Auto
CategoryValue
Hardness20
Regen Day14
