david gosnell
i bought a 4 wire submersible pump for my well before i realized my well is a 3 wire controlled by a pressure switch can i still use the 4 wire pump without the neutral wire
You can if you get a control box that matches the motor. However, using only three wires means it won't be properly grounded, bonded or up to current code. In addition, some say that leaving the ground wire from the motor unsealed will allow water to wick into the pigtail socket and cause dead shorts to ground.
Just because you can doesn't mean you should.
100 years of pumps with either just 2 wires or 3 wires and a control box. That new ground wire is some over educated, under experienced "engineers" idea to waste a few more thousand tons of copper a year. When I cut off the irrelevant ground wire, I rubber tape it and top everything with Scotch 33. Soon as someone can give a detailed answer what in hell a ground wire does for a pump a few hundred feet under water, I'll use it.
Are you planning to put GFCI breakers powering submersible pumps soon? I certainly would not want my basement sump pump powered by a GFCI, although I know it is required some places.I bet you don't like those new fangled GFCI outlets either.....
We do tons of well inspections for real estate transactions every year, one of the biggest violations we see are ungrounded/bonded pumps, well caps & steel casings.
No, of course not.
If you were to see some of the horrible pump installs we see with poorly spliced wire, old chafed wire & bare wires under well caps due to rodents you would know why having a properly grounded and bonded submersible pump system makes perfect sense.
