I have a 2" steel well casing, with a Wayne 1/2 hp convertible jet pump, well approx 90 feet deep. I need to remove the pump to replace the impeller, looking at the install, the easiest way to remove the pump would be to remove the discharge line, unbolt the motor, and I think unbolt the 3 bolts holding the casing adapter that is fixed to the top of the casing. I am not familiar with this setup and want to make sure that I will not loose the suction pipe down the well if I remove those bolts????? The pump has two lines from it to the casing adapter. The casing adapter is a 90 degree elbow with the two pipes going into it. The elbow is yellow and has 3 bolts holding it together. Is this the best way to remove the pump for impeller change?
