2 heaters, 1 thermostat in middle
Qwertyjjj
Current setup has a heater with built in thermostat.
The source goes to heater 1, then a parallel connection to the thermostat and then onto heater 2.
What I want to do is have the thermostat control both and remove the built in thermostat.
I know how to make the connection so that the themrostat controls heater 1 but how do I reconnect heater 2 with the new setup? Do I just parallel wire nut in heater 2 to both lines of the tstat?
1st image is current setup.
2nd image is what I want to do but not sure about 2nd heater.
It's not clear to me if the existing thermostat is line voltage, or low-voltage. It appears to be line-voltage, so if you combine two of them, the new thermostat would need to be able to handle the sum of the load. Do you have model number and brand? Have you looked for the installation manual, either stored away at home or on-line?
Qwertyjjj
It's line voltage.
I am removing the first thermostat that is built in.
The digital thermostat can handle both, or can handle up to 2300W which is more.
What I'm not sure about is the wiring for the second heater since the setup is now changing a bit. Source currently goes into the digital thermostat junction box bit when I change the source will only go into the first baseboard heater.
Installation manual doesn't list this setup.
Qwertyjjj
Also, because the heaters are a tiny bit longer than the old ones, I'm finding the existing wire a bit short.
Can I put a junction box behind the heater and use a wire to bring it to the junction box in the heater so I don't have to replace any existing cable?
Run the power to each of the heaters in parallel from the thermostat as long as you're positive it can handle the load of both of them. You might need an additional box if the contacts in the thermostat are not designed for multiple connectors and/or if there isn't room to daisy chain or combine them in some manner within the envelope of the thermostat/box.
I'm not positive, but a box could work...hassle is, I think code requires access to any box, and if it is covered by the heater, that probably won't work.
Kreemoweet
Seattle. WA
You're going to have to run new wiring to do what you want. Either a new 2-conductor cable from heater 2 to
heater 1, or else replace the 2-conductor run from heater 1 to t-stat with a 3-conductor cable.
A junction box is considered accessible, even though it requires removal of equipment to access
it. Some baseboard heaters are in fact configured so that such a box can be accessed without
removing the heater.
WorthFlorida
Solutions
Orlando, Florida
To get a few more inches added to a short wire, these will work. These work great especially if the wire from the box is real short and barely any wire to grab onto for a wire nut.
https://www.homedepot.com/p/Ideal-S...PIPHorizontal2_rr-_-202204326-_-203734798-_-N
