CCinPA
Can I connect a 12v transformer to a 12v rechargeable battery to recharge the battery?
Buy a battery charger with automatic control. What kind of battery? If it is a 12 volt lead-acid, I would consider a Battery Tender charger made for motorcycles if it is fast enough. It is easier on the battery than faster chargers.
You have a steep learning curve before you can get something to work. As HJ noted, you CANNOT apply acv to a battery. A battery requires dcv, and you don't get that directly from a transformer. You need to first rectify that voltage and have some sort of regulation and some means of ensuring you don't overcharge the battery which can literally blow it up or start a fire if done incorrectly. FWIW, if the full charged level on the battery is 12vdc, typically, you need to feed it a higher voltage. Too high, it doesn't work. Applied too long, you can destroy the battery. There are different chemistries of 12vdc batteries, and they each have their own charging curve and actual fully charged value.
And, yes, a typical 12vdc battery charger is plugged into the 120vac wall socket, but, that does not mean it even uses a 120-12vac transformer (10:1), the output would need to be higher than 12vac to be able to regulate it to where it needs to be.
How do you have 12 volts AC available and not 120 volt AC? Usually a 12 volt transformer has 120 VAC on its input side.Isn't a battery-tender 110v in? If so, the source I have is the 12v transformer.
OK. That describes the load. If we presume 2.4 amp-hours from an alkaline battery and the battery lasts 48 hours, that would be about a 50 millamp load. Sound like it might be 1 or more LEDs, but it could be something else.Currently I have a garden-ornament that is powered by a AA(1.5v). As you might expect, the battery only lasts a couple days.
