Master Plumber Mark
Got to give an estimate to someone this weekend
to tear up the floor of the basement and installan ejector pit,
pump and all the pipe necessary for a full bathroom ........
Their is absoulutely NO WAY in hell to install a vent out the roof
or revent it into an existing vent above the second floor.....
without cutting through walnut and cherry walls, marble panels ect all in the way .....
So I explained to the customer that I would simply have to
cut the main 3 inch PVC line TWICE and use it for both the
vent and the drain to this new bathroom...
In my opinion, being a 3 inch drain line it will work fine , though it is
techneiclly not "kosher"
running the 2 inch vent as high as possible in the rafters and then dropping
down into the 3 inch pipe UP- STREAM of the discharge pipe...
will work for years and years to come...........
the only other possible avenue is to go under the kitchen sink
with a re-vent pipe and tie into that vent in the wall
In others opinion,
When you have no other optioins that are feasable and or cost affective,
what is the best plan of attack????
In others opinion,
