water level drop
Discussion in 'Shower & Bathtub Forum & Blog' started by johnfrwhipple, Dec 25, 2011.
  1. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Leo are you cutting down the Kerdi Curb you bought so it's not so huge?
    Posts removed by John Whipple
    Sorry Folks - I have taken down my post on Schluter's products. Just being careful with my wording.
    There is very little info online on the subject of flood testing a Kerdi shower. I have used Kerdi now on many shower builds and have so for years (about 13). I follow the European installation protocol and over the last 16 months flooded many Kerdi showers. None dropped in level at all. Not a 1/8".
    Your key steps is measuring the water level exactly and ensuring you get no capillary wicking. To learn how to do this call Schluter or call me. My number is below. I have documented the process over and over and have dozens of detailed photo's showing the measures I take so you do not fail this oh so important step.
  2. eurob
    eurob master tile and stone installer
    Feb 16, 2013
    Montreal
    I think you are mistaken the width of the curb - large as you call it - with practical when cleaning the shower floor or even use it as a step. Other than aesthetically a narrow vs. large curb doesn't serve any purpose.
    No curb or curb less is a different story .
  3. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
  4. eurob
    Feb 16, 2013
    Montreal
    Besides the possibility of cutting the curb , massiveness could be resolved . And there is no water pressure , head pressure -- other than the one added by singular thinking -- or any other pressure you see with using it.
    Oh , I got it...... A chance you didn't see the Eiffel curbes I am building... LOL
  5. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
  6. loudgonzo
    loudgonzo New Member
    Jan 7, 2014
    Wylie, Tx
  7. eurob
    Feb 16, 2013
    Montreal
    No kidding..... As soon as I mentioned curves...... I know you got disoriented. LOL
    Maybe later. Such pain to type on this crappy phone.....
  8. jadnashua
    A good porcelain tile has less than 1% absorbtion rate. Take your grout example...the head pressure is still WAY less than in the flood test. The head or water pressure on the membrane of a surface membrane shower is never worse than in the flood test, and if it does not leak then, it will never leak.
    Looks aside, and there's no reason a Kerdi shower need look any different than a conventionally built one, if the workmanship is properly it DOES NOT LEAK! There are lots of acceptable ways to build the curb and the pan can use their tray or be made from deckmud. As long as the shape of the pan conforms to industry standards, once covered with Kerdi, it is fine.
    The quality of the finish work has no reliable relationship to how well it was waterproofed. A beautiful looking shower can leak just as easily as a lousy one be watertight.
    FWIW, there are some places in Hawaii that average nearly 400" of rain a year, verses some in say Arizona that may average 5". Does that mean that a roof in HI will leak verses one in AZ because it sees more water? No, properly built, they are both waterproof and protect what's underneath them.
  9. loudgonzo
    Jan 7, 2014
    Wylie, Tx
    John, can you post a picture of the shower in progress with the low curb when its completed? I like the tiles and want to see how the this one turns out, especially the floor.
    thanks,
    Leo
  10. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
  11. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
  12. jadnashua
    Can anyone show me where a porcelain tile broke loose from Ditra or Kerdi in an actual install when it was installed per Schluter's recommendations (this includes proper prep of the floor)? Yes, you probably can if there were not one of those membranes underneath it. The Robinson floor test of DitraXL on a 24" joist spacing (really stressful), installed per Schluter's recommendation gets a heavy or extra-heavy rating, depending on the tile size. This is better than installation at 16"OC with a cbu...so, who are you going to believe? The manufacturer that has the independent TCNA test results to verify it, or someone like John Whipple that just doesn't like me or Schluter, or believe they know how to install their own products? Those test reports are: TCNA-303-06 and TCNA-153-09. You can look them up yourself, if you don't believe me.
    As to bond strength, the TCNA also did some tests with porcelain tile with unmodified mortar, and came up with the following shear test average values of 277 and 365psi. Those test results are in TCA-073-03 and TCA-186-03. If you extrapolate those results to a 12x12 tile, that comes to 144*277= 39,888 or 144*365=52,560. I think, along with the long-term experience with their use AND the independent test results, John is blowing smoke.
  13. Vegas_sparky
    Vegas_sparky Digital Billy
    Dec 5, 2013
    Electrician
    LV,NV/ Nowhere,UT
    These flood tests are really boring. Aside from adding more water every 15 minutes to keep half the coin covered, there's nothing to do.
    [​IMG]
  14. eurob
    Feb 16, 2013
    Montreal
    If you build your water dam right , no more adding is needed . Like this one
    LOL
  15. Vegas_sparky
    Dec 5, 2013
    Electrician
    LV,NV/ Nowhere,UT
    What dam? I just kept smearing that red crap all the way to the top of the speedbump.
  16. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
  17. Vegas_sparky
    Dec 5, 2013
    Electrician
    LV,NV/ Nowhere,UT
    Oh, I'm funny. LOL
    I had flood tested it with a plug after the liner install, and again after the screed bed with the plug. During the second test with the plug, the water level dropped very slowly. I didn't know if it was because I had poked a hole in the liner while the top layer went in, of if it was migrating through the weep holes. That was really bothering me.
    A third test with a ball below the weep holes and I'm sure I have no leaks. I have so much confidence, I'm going into the shower building business..
    In Vancouver. (I get 10% of the cut from my junk you have to fix).
    See, that's funny.
  18. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
  19. wilkinte
    wilkinte New Member
    Jan 9, 2014
    Utah
    Hey John, Tom from Utah back. While my flood testing went great, I'm a challenged tiler. Anyways, removing chipped tiles from my floor and I breached the kerdi, see pics. Sikaflex work here? hate to wait for kerdifix, could just thinset another layer down. Any advice appreciated!@! Salt Lake City-20140120-00059.jpg Salt Lake City-20140120-00060.jpg
  20. jadnashua
    If you patch with Kerdi or Kerdiband and maintain at least the 2" required overlap, it will be fine.
Similar Threads: water level
Shower & Bathtub Forum & Blog 2nd floor shower drain water level? Mar 28, 2010
Shower & Bathtub Forum & Blog Moentrol, Only hot water coming from Moen shower Aug 11, 2016
Shower & Bathtub Forum & Blog Water goes down slowly in Tub/ shower Jun 26, 2016
Shower & Bathtub Forum & Blog Water comes out from shower diverter spout May 23, 2016
Shower & Bathtub Forum & Blog New water heater issue?? Apr 15, 2016
