water level drop
Discussion in 'Shower & Bathtub Forum & Blog' started by johnfrwhipple, Dec 25, 2011.
  1. jadnashua
    One of the advantages of taking a workshop is that you get to actually touch and see the product, while we did each get a chance to install a pan and regular drain, we only got to touch and feel and see one of the instructors install a linear drain (probably a cost thing, and time). But, they opened up two or three boxes to show the center drain, the offset drain, and then one each of the various drain covers so we could look and hold and see how they were installed. The finished grates get installed differently than the tile-in grate cover, and we got to see how to adjust the finished grates and body so that the tile were at their proper level. With the tile-in cover, it's easier, since whatever thickness tile you use is the same on both the cover and the surround. If you've never taking one of their workshops and are in the business (tile setter, store owner, general contractor, architect, building maintenance, or others as approved by the area rep), you should. Seeing someone who knows how to use new products do it once and then get a chance to immediately try yourself is much better than winging it by yourself for the first time. Schluter runs about 40 of these across the country a year, but, it is a big country, so you may still have to travel a bit to get to one. The first step, though, is to talk to your area rep.
  2. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Plastic.
    That's a nice touch. Won't the Thermal Mass of the Plastic fatigue with the cycling of hot and cold water? Or is the plastic special German Plastic that is molecularly designed for thermal stresses.....
    LOL
  3. eurob
    eurob master tile and stone installer
    Feb 16, 2013
    Montreal
    Oh , John , c'mon ....not again .
    I don't want to know , nor I am interested to know how the S drain was born LOL
    I don't care about the plastic thinggeeee .....is not in the box ........I really do like the ACO strainer .
    We also past the strainer -- touch and see -- through some hands in the room there .... the vendor , the cashier , me......Hahahahaha.
    Now , send the tile police after me since I don't use the S products as intended . Am I out of my mind -- design my own grate -- not to respect -- to the Tee -- the recommendations from the package -- not one language , not 2 books , but 3 different surplus items !? --
  4. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    English Question
    Roberto do you have the plastic hair strainer?
    I'd like to buy it. Just for my own research.
    Want to compare flow rates and molecular structure of the water particles passing through the vortex of the concave design. In Ancient Greece they used woven non-modifed grape vines for the first hair strainer. Later the Egyptians used reeds bonded and dried in the sun to catch hair before it enter the Nile.
    I'll go as high as $4.00 for your plastic strainer.
  5. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    In French
    Roberto avez-vous la crépine de cheveux en plastique?
    Je voudrais acheter. Juste pour mes propres recherches.
    Vouloir comparer des débits et de la structure moléculaire des particules d'eau passant à travers le vortex de la conception concave. Dans la Grèce antique, ils ont utilisé tissés vignes non modifed pour la première crépine de cheveux. Plus tard, les Egyptiens roseaux utilisés collés et séchés au soleil pour attraper les cheveux avant d'entrer dans le Nil.
    Je vais aller aussi haut que 4,00 $ pour votre strainer.Roberto plastique vous avez la crépine de cheveux en plastique?
  6. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    In Spanish
    Roberto ¿tienes la trampa de pelo de plástico?
    Me gustaría comprarlo. Sólo por mi propia investigación.
    ¿Quieres comparar las tasas de flujo y la estructura molecular de las partículas de agua que pasa a través del vórtice del diseño cóncavo. En la antigua Grecia se utilizaron tejidos vides de uva no modifed por primera trampa de pelo. Más tarde, los egipcios utilizaban cañas unidas y se secan al sol para coger el pelo antes de que entre en el Nilo.
    Voy a ir tan alto como $ 4.00 para su strainer.Roberto plástico tiene usted la trampa de pelo de plástico?
  7. ShowerDude
    ShowerDude Showers
    Apr 7, 2014
    Minnesota
    I always mix MFG products, orange , blue, green all of em. Whatevers in my trunk that day. How else can i claim to have built a custom shower?
  8. eurob
    Feb 16, 2013
    Montreal
    John , I would give it to you for free , but it is not there -- poking you -- in the box . I should've read the instructions .....I think I will call Erich von Däniken .
    Oh man , we need more smilies LOL:D
    C'est beaucoup plus chere une crepine ....comme ça
    [video=youtube;pMNKUXnzFyY]http://www.youtube.com/watch?v=pMNKUXnzFyY[/video]
  9. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    You wanna see the lifting key I got with my Kerdi Line Drain?
    It looks like a toilet cleaning brush... LOL
    JW
  10. Vegas_sparky
    Vegas_sparky Digital Billy
    Dec 5, 2013
    Electrician
    LV,NV/ Nowhere,UT
    Roberto, that is one of the coolest shower/ tile designs I've seen. Bravo, man.
  11. eurob
    Feb 16, 2013
    Montreal
    :) Thanks , William. :)
  12. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Vegas how is your shower working?
    Did you do the testing with the grate off?
  13. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
  14. Jean-Claude JC Lussier
    Jean-Claude JC Lussier New Member
    Apr 17, 2014
    Manitoba
  15. Jean-Claude JC Lussier
    Apr 17, 2014
    Manitoba
    It is the schluter shower kit surrounded by a custom bench on 2 sides. The floor is using the schluter floor pan.
  16. Jean-Claude JC Lussier
    Apr 17, 2014
    Manitoba
    The original water line was in in fact just 1/4" below the top of the curb. The water was about 5" deep.
  17. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    I would run a bead of Kerdi Fix along the top of the curb. Or top the curb with a little Ardex 8+9. Either would act like a capillary break for the flood test.
    If your using a tile profile for the curb top you could set that with Kerdi fix and that would be an awesome capillary break. If you are setting 3/8" tile I recommend a 1/2" or 5/8" Stainless steel profile. This will allow some setting material below and account for the grading of the curb.
  18. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Jean Claude - I hope my tips help you out. You do realize that Schluter has no specification for a capillary break. They require flood testing but offer up no insight for this capillary leaking.
    I don't think Noble has a spec either.
    Nor does Laticrete.
    Yet all will suffer from the same fate unless you tackle the capillary beast. Thanks for liking my post. I'm sure Jim will respond and tell you my idea is crazy. Not allowed. That your warranty will be screwed or to double check on the John Bridge forum.
    But those ya who's don't know either.
    I had the pictures up before but deleted my Kerdi info....
  19. jadnashua
    Capillary action requires a pond of water. Once you put your tile on top and grout it, the amount of liquid water that gets underneath the tile is miniscule and over a membrane, if your slope is proper, that that does not flow down the drain on top of the tiled surface and soaks in will evaporate before it gets a chance to wick anywhere it could cause damage. But, if your slopes are incorrect, you could have an issue.
Similar Threads: water level
Shower & Bathtub Forum & Blog New tub level, but doesnt drain water all the way Nov 14, 2016
Shower & Bathtub Forum & Blog 2nd floor shower drain water level? Mar 28, 2010
Shower & Bathtub Forum & Blog New tub/shower set up, not enough water pressure Jan 16, 2017
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
Shower & Bathtub Forum & Blog Water runs from handheld and wall shower same time Oct 23, 2016
