Tub spout installation with a threaded drop ear elbow?
KLRmoose
OR
Hey guys
I'm working on my bathroom remodel and decided to use a bathtub surround. I have a Delta shower valve and soldered on a 1/2" copper tub spout. I was going to install the surround but realized the surround peice that sits against the shower valve/tub spout wall has to be slid into place. That means the tub spout can't stick out past the face of the surround.
The directions call for a certain distance stick out from the surround to install the tub spout. Can I used a drop ear elbow to threaded pipe nipple? I would imagine I would want to use a brass nipple. I'm worried that with the small tolerance I won't be within the proper stick out from the surround that the tub spout calls for. I could probably buy a longer nipple thread it to the proper length.
Just not sure of the proper thing to do in my current situation.
Thanks for your time!
Here are some pitchers showing what can be done with tub shower kits.
Drop ear and brass nipple.
Here with a Delta trim.
C-3 shows the install with the brass nipple.
John Gayewski
Iowa
I like to use copper pipe and the delta tub spout adapter. It can be used with threaded pipe or copper.
I use a threaded drop ear , with a threaded nipple capped off then on finish I either use a proper length nipple preferably brass, or I put a male adapter on a copper tube and screw that in
