Spring Startup Help
Discussion in 'Irrigation / Sprinkler Forum' started by Flyjetz, Apr 25, 2009.
  1. Flyjetz
    Flyjetz New Member
    Apr 25, 2009
    I'm trying to get my sprinkler system restarted this Spring and can't seem to get the water past the backflow preventer. Here's what I've done:
    1) I closed all the drains.
    2) I opened the water main about 1/8 of a turn.
    3) I opened both ball valves on the backflow preventer (parallel to the pipes).
    4) I made sure the brass threads were closed (perpendicular).
    5) PROBLEM: WATER IS SURGING OUT OF THE TOP OF THE BACKFLOW PREVENTER.
    6) I tried turning on each zone to see if I could get water to flow into the zones anyway. No luck.
    I'm a novice. Has anyone seen this problem, or have any idea what I'm doing wrong?
    Thanks!!
  2. Terry
    Aug 17, 2004
    You need to open up the valve more.
    It's takes water full on to push the seal closed on the vacuum breaker.
  4. Flyjetz
    Flyjetz New Member
    Apr 25, 2009
    Problem solved!! Thanks!!
  5. PSLawnService
    PSLawnService New Member
    May 16, 2009
    Lawn Service - Owner
    Minnesota
    1. Close all valves and test cocks on the backflow
    2. Turn water source on (easy does it) all the way
    3. Program you controller for a short (4-5 Min.) watering cycle. Start it up.
    4. On the PVB (Backflow Preventor) determine the direction of the water flow
    5. Turn on the source side first-briskly to reset the backflow.
    6. Turn on the irrigation side last, slowly at first to fill the underground pipes.
    Zone 1 should already be open, allowing the underground pipes to not be
    air-locked.
Similar Threads: Spring Startup
Irrigation / Sprinkler Forum Turning on sprinkler for spring Mar 14, 2012
Irrigation / Sprinkler Forum spring start up question May 21, 2009
Irrigation / Sprinkler Forum Turning on in ground sprinkler system for spring May 6, 2009
Irrigation / Sprinkler Forum Rain Bird ISM Springler Timer Aug 7, 2008
Irrigation / Sprinkler Forum Trouble Turning Sprinklers On This Spring Apr 26, 2008
