Replacing tub faucet
Discussion in 'Shower & Bathtub Forum & Blog' started by rurulesunc, Apr 6, 2006.
  1. rurulesunc
    rurulesunc New Member
    Apr 6, 2006
    Hello all.
    I just moved into an apartment and am trying to add a tub spout with a diverter instead of the one there now that doesnt have the diverter. My problem is that the old spout is so old and (I assume) corroded that I cant get it off. There is no set screw that is visible. I have tried using a screwdriver to get leverage and then bought a pipe wrench out of deperation. The pipe wrench just bent the existing spout.
    Anyone have any ideas on how to get this thing off the wall?
    Thanks for any advice you can give.
  2. chassis
    chassis Engineer
    Sep 12, 2005
    Engineer
    SE Pennsylvania
    ruru,
    Your current tub spout has no diverter? Is it a tub only or tub + shower? How is the shower activated now? What do you hope to achieve by adding a diverter if there isn't one in place now?
    Typically there are threads inside the spout that engage with a pipe that goes into the wall. If you are replacing the spout, and are OK with destroying the current one, you have options. Take some big channel locks (slip joint pliers or water pump pliers) or a pipe wrench, grip it and twist the spout. Something will give. Or put a thick wood dowel into the spout and use it as a lever to unscrew the spout. It's possible you may also damage something inside the wall while doing this, and you're into a bigger project.
    If you're not comfortable with the risk of damage to the spout or inside the wall, call a plumber and have him do it. Probably one hour's worth of work and $100 max.
  4. rurulesunc
    Apr 6, 2006
    Thanks Chassis.
    Yeah right now the apartment only has a tub and I want to add a spout with a diverter to convert it into a shower. Since its an apartment I cant do any work inside the wall, only cosmetic changes but I have gotten the ok to add the diverter and a shower head with a long cord that connects.
    I think its time to call a plumber I was just trying to avoid the cost but better safe than sorry I guess. I dont want to break anything in the wall.
  5. jadnashua
    Often, the walls around a tub only system are NOT waterproofed. Adding a shower may destroy the walls and tile that are there now.
    Most divertor tub spouts do not have a hose connection for a shower...they expect the valve in the wall to handle that. Might be tough to find.
  6. rurulesunc
    Apr 6, 2006
    I already have the diverter with the conection that I need and the shower head to go with it. The wall issue is one that I havent thought about.
    I know that the wall that the shower would attach to is tiled to shower height but I havent paid attention to the side wall. I guess I could always get another shower curtain to put on that side to protect the wall if it isnt waterproofed.
    hmmm
  7. chassis
    chassis Engineer
    Sep 12, 2005
    Engineer
    SE Pennsylvania
    ruru,
    Just because one of the walls is tiled does not mean it is waterproof. The grout is porous, and water will get between the tiles. If the proper tile adhesive (thinset) was not used, and the wall properly waterproofed, the entire wall will turn to mush. Not sure there is any way to verify how the wall was built without tearing into it.
  8. rurulesunc
    Apr 6, 2006
    Gotcha. Thanks for the info.
Similar Threads: Replacing faucet
Shower & Bathtub Forum & Blog Moen Posi-Temp, replacing cartridge of bathtub faucet single handle Sep 26, 2016
Shower & Bathtub Forum & Blog Replacing a three handle tub shower faucet with Moen Posi-Temp Feb 22, 2014
Shower & Bathtub Forum & Blog Replacing a MOEN bathtub faucet with a Kohler Mistos Oct 8, 2012
Shower & Bathtub Forum & Blog replacing shower faucets and head Apr 6, 2011
Shower & Bathtub Forum & Blog Replacing Shower Faucet Handle Aug 31, 2008
