Remove Roman Tub Spout
yellbird
Monee
I was hoping some would read these pdf files and let me know if I could just unscrew this spout and install new one, if not I would have to cut hole in wall to get underneath tub.
Thanks for any advice
  • Spout.pdf
  • Tub Spout.pdf
It depends on how it was put together underneath. Normally with those instructions, any plumber would be leary of starting that job, unless there was the option to open things up.
That is a thread on spout, and maybe you can, and maybe you can't. If it unthreads fairly easily, then maybe yes.
If you are lucky, it will unscrew from the pipe and NOT drop into the space under the tile. IF not, and uscrews from the tee underneath, then you will have to make a hole to put it back together. Do you "feel lucky"?
yellbird
Monee
Thanks for your fast reply, I figured that would be about the best I could ask for, looks like I will purchase of of those hole covers before I start messing with it. The spout has a half dollar sized polished brass chip messing from the top but it works fine other than that.
Thanks very much
yellbird
Monee
About the same as my first reply, looks like I will go buy lotto ticket to see if I am lucky Ha.
Thank you very much for replying.
From the drawing, the "spout shank" looks like a nipple of sorts that is at right angles to the surface. I would picture that angle when attempting to unscrew the spout.
Because I don't have the experience, I don't think things will go wrong. I figure that nipple will either stay with the spout, or it won't. To remove that nipple from wherever it stays, if you want to, I would look to use an internal pipe wrench.
The drawing shows solid piping to connect the spout to the valve handles. Nobody knows if this was done.
It could have been tied together with soft copper, flex connectors, or copper pipes.
If it was done with flex connectors, then spinning the spout may turn all of the piping below.
When hj and I say that it scares us, it's because we have seen those done so many ways. It's typical with a spin on fitting, that you need to back it. Holding pliers or a wrench on the back side.
yellbird
Monee
Just wanted to Thank everyone for replying. Was able to turn spout and release it from water pipe but nut kept spinning with it so couldn't
pull spout out. Ended up cutting small hole in wall removed and replaced spout. Thanks again for all the advice.
Thanks for the update.
So many deck tubs out there, and sometimes we get calls to repair them or to change out the trim as styles change.
Sometimes, parts have changed, and it can get a little sketchy doing them if you don't have access below the deck.
This tub had a crawl in access. I had half my body in there.
This is the old spout. It was kind of short.
We replaced with a longer one.
FullySprinklered
Georgia
You look bigger in your picture. Must be the coat. Got lucky today putting in my first Hansgrohe kitchen faucet. I managed to squeeze into the cabinet but I could barely breathe. Once inside I almost couldn't function. The brace between the cabinet doors was tight at my waist and I had to plan every move to keep from getting jammed up. The sink cabinet was a corner job and the space got bigger toward the back. I noticed that the center piece on the face frame was installed with screws installed in predrilled Kreg-type slots. That was good news for me since I was able to get a square-drive bit and remove it temporarily while I was in the cabinet and reinstall it afterwards.
The faucet was a fine piece of machinery. Everything worked smoothly, the built-in supply tubes went all the way down to the cabinet floor, and the instructions included real words, some in English.
