Pop Up Drain in Vessel Sink Drains Slowly
rickparsons
Colorado
I have a vessel sink that drains slowly. I figured it was the lack of positive pressure. I have a pop up drain with just two small oval openings for water and air to go through. Any recommendations on how to get past this problem on a sink with no overflow? Thanks.
Cass
many of the older designs can't be raised more...some of the pop ups are on the rod wrong by 180 degrees...
rickparsons
Colorado
Pop Up Drain pictures
Here is a picture of the relatively new drain from inside the bowl and below the vanity. It looks like I can raise the threads.
rickparsons
Colorado
Thanks for everyone's input. It's too bad if we have a drain with that problem. Does anyone have a recommendation for a replacement pop up drain? Thanks.
Making it drain quickly with a K-7124 pop-up drain for vessels.
A vessel lav without the overflow will not drain well unless the drain opening allows a lot of air through.
The old standard grid drains for pubic bathrooms used to work because the lav had an overflow near the top, allowing air to pull through. The small holes of a grid drain tend to stick the water and the basin fills up instead of quickly draining out.
Some drains are made for this. One way is a pop up drain that gets high enough to allow air to pull through. Come make an domed and elongated grid drain that gets high enough to allow some air through. I prefer the drains that pop up fairly high.
The pop-up drain gets high enough.
