Glad you got the pump working. But I am afraid even a camera is just prolonging the inevitable digging.
Start at the wettest spot.
It's a 7 gpm pump. That is significant if you are to replace the pump.It's a Grundfos 1/2 HP 230V 3 wire pump
A leak finding specialist might be able to find the leak with special equipment. But an alternative would be to have a new pipe trenched in. I don't know what that might cost.
Why do you suspect the path that you do? When you stuck the probe in, did you feel a discontinuity there? A fish tape used for pulling electric wires in conduit seems like a good probe.
If there is an elbow, that seems like another good place to get a disconnect.
If you have that pump out again, consider measuring the deadhead pressure. Expect about 178 psi. Only power the pump for a few seconds, because the pump is not being cooled by water flow.
I think you should be pleased. Yes, you have significant work ahead, but you found the problem with your first dig.With that said, I turned on the well and a small pool appeared by that elbow so that's where my leak is. I just can't get access to it because of all the roots. Disappointing but what can I do.
Yes and leaks will be a continuing problem until you get rid of the tree. Got a big tree I am having to cut for the same reason.
Hi Reach4, a bit more background.A missing or defective o-ring on the inside of the casing would cause water to drop down the well-- not into the yard.
If you are getting leaking to the yard, that would need fixing outside. Your photo of the pitless is not sharp. Does the pitless have a big hump outside of the casing, and is that hump welded in place?
Is that pitless picture of the same hole that the tree picture shows? Your well person is going to need to do some serious cutting of that tree, I would think.
When you lift the pitless inside, what does it look like?
