Electrical Base Board Heaters from Home Depot-REVIEWS?
Discussion in 'Electrical Forum discussion & Blog' started by 87vertgt, Sep 10, 2009.
  1. 87vertgt
    87vertgt New Member
    Sep 10, 2009
    Chicago,IL
  2. jimbo
    jimbo Plumber
    When you install these, they should be on a dedicated circuit. Make sure you know before you buy what volt/watt/amp will be required and that you have that available
  4. Ford2001
    Ford2001 New Member
    Sep 11, 2009
    property care taker
    Manchester, Vermont
    Before I would install any electric baseboard heat, I would want to
    know what the power company charges per Kwh.
    I have installed both electric baseboard and force air electric heat.
    The baseboard electric heat ran about 250 watt per Foot.
    Some electric baseboard heat run at 120 volts, other at 240 volt.
    Electric baseboard can have a thermostat install directly to the
    unit. Or you could install a thermostat remote from your heaters.
    You will find that, is this becomes your primary source of heat, your electric
    company will send huge bill each month. Plus an x-mass card at christmas.
    Next how big is your electrical service to your house.
    If you have a high income, and money doesn't matter, becuase you
    have more then you can spend.
    Then electric heat is nice. You don't buy oil, gas, to fuel your furnace
    or boiler. But it is a dry heat, so you probable want to invest in a
    humidifier
    Also ask your power company if they have an off peack rate avaible for
    things like electric storage hot water heater and electric
    Where I live they do, and they can shut it off for about 4 hours n the
    morning and 4 hours in the evening.
Similar Threads: Electrical Base
Electrical Forum discussion & Blog New basement electrical circuit Sep 27, 2015
Electrical Forum discussion & Blog Basement electrical wires Feb 5, 2013
Electrical Forum discussion & Blog Electrical supply to barn and garage Feb 9, 2017
Electrical Forum discussion & Blog Electrical panel- no ground Feb 1, 2017
Electrical Forum discussion & Blog Electrical wire accidently charred. Dec 31, 2016
