Change ShowerHead at Attachment
Discussion in 'Shower & Bathtub Forum & Blog' started by CZChang, Sep 5, 2012.
  1. CZChang
    CZChang New Member
    Sep 5, 2012
    New York
    Hi - I'm looking to replace this showerhead, but only at the female/male attachment. I'm quite new to this so I'm not sure what type of specifications I should be looking at to make sure the new one I buy will successfully attach at the indicated point. How do I know when buying a new showerhead that it will be able to join at that point?
    Doing some research, my current one seems to be either
    1) http://www.homedepot.com/h_d1/N-25e...shower+head&storeId=10051#product_description
    OR
    2) http://www.homedepot.com/h_d1/N-25e...eyword=shower+head&storeId=10051#.UEfdmY2PVvE
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  2. kreemoweet
    kreemoweet Member
    Sep 7, 2009
    Seattle. WA
    The showerhead actually begins upstream from the joint you display, with the first nut that screws onto the pipe emerging from the wall. It is probably
    a standard 1/2" Female Pipe Thread nut, which you will also find on just about any replacement showerhead. If for some strange reason you actually want
    to replace only the parts you have removed, you will probably have to find an identical showerhead and dismantle it to get the items you need.
  4. jimbo
    jimbo Plumber
    San Diego, CA
    Not going to happen......EVER. brands and models NEVER mix and match at the fittings.
  5. hj
    The only thing that will fit where you want to mount it is another shower head EXACTLY like the one you have. Take the other piece off the shower arm and you can use any shower head you want to.
Similar Threads: Change ShowerHead
Shower & Bathtub Forum & Blog Shower head sizes???did they change? May 30, 2016
Shower & Bathtub Forum & Blog Change Delta Shower Catridge Mar 27, 2016
Shower & Bathtub Forum & Blog Pfister - Change Compression to Ceramic? Feb 9, 2014
Shower & Bathtub Forum & Blog PP Crown Imperial interchangeable with Crown Imperial? Jul 4, 2013
Shower & Bathtub Forum & Blog should I change the p-trap? Jun 4, 2013
