I screwed the flange to the concrete floor using Tapcon screws. After seeing how plastic flanges crack under tension, I will not install another flange without screwing it to the floor.
Thanks for the help!
I need to drill some holes in porcelain tile to screw down a toilet flange.
Should I drill the holes before or after the tile is set?
Can anyone recommend the bit and or technique to use?
