I have a point well that I put a new pump and pressure tank on. I still have the same trouble I had with the old system(the addition of the pressure tank does help at the start of water usage). It takes a really long time to get water. Eventually it will build up pressure and when water is used, comes out great at first. As the usage continues ( a shower for example), the flow drops off to hardly anything. If we leave the cabin for even up to a month and come back, the system holds its pressure. The water sits about 5 feet from top of the pipe and when I measure the well with string and weight, I get 21 feet. Any ideas without pulling it up and installing a new point and pipe?
