krazyinktattoos
We've never had what is call great water pressure here but over the last month or 2 it started getting progressively worse. There has been several times now that I'm the middle of taking a shower the water pressure would drop to barely a trickle then return to normal after 30 seconds to 2 min. I finally went down to the pump house to try to figure out what was going on. The things I know aren't as they should be are; pump never cycles off, pressure tank isn't filling with water, pressure gauge reading at 35psi. What I've done so far; verified correct tank pressure(had to add a little air to bring it up to 38psi, our switch is 40/60), replaced the pressure gauge(just in case), verified pipe to pressure switch wasn't clogged. A new pressure tank and switch were installed in 2020, the air pressure in the tank has stayed at 38psi for several days now, when I put my ear near the cap for the pump I don't hear any obvious abnormal sounds and when I cut the power to the pump the water pressure stays at 35psi. Unfortunately I don't know anything about the pump or how deep the well is. I really need some help diagnosing this, I have very limited income and don't want to call a pro unless I have no choice.
