I know this is yet another basement venting question, but I appreciate any help! I am finishing my basement and when I built the house 14 years ago, I had the plumbers rough in a bathroom in the basement but I am not sure what they did under the concrete. They have since gone out of business (If you saw their work you would understand why) so I can't call them and ask. I am attaching a drawing of our current plumbing and what I think they may have done under the concrete but again am not sure. The basement bath will have a shower, toilet and sink/vanity.
The basement bathroom will be directly under the master bath. I know the master bath vanity vents though up to the attic. It doesn't appear that any of the other master bath plumbing has their own vent to the attic, other than what I show in my picture. I didn't show any of the traps or wye connections in the drawing but they are there for the existing master bath plumbing.
I ran a camera up the 2" pipe in the shower hole in the slab as far as I could. I think I made it close to where the toilet flange is roughed in and hit an elbow or Y but couldn't tell which.
So here are my questions:
Do you think the 2" coming from the shower hole in the slab is a vent or drain?If it is a vent, did they intend for me to tie into the 3" under the concrete next to the hole for the drain? Seems like that would require removing some concrete as the 3" is fully under the slab, though flush with the exiting hole in the concrete. If it is a drain, it was not capped off under the gravel in the hole. Also if it is a drain, can I tie a vent into the 3" vertical next to it.
The vanity will be on the opposite side of the wall of the shower with the 3" vertical. Can I tie into the 3" vertical for the vanity drain and vent as shown in red and green in my picture?
Finally, I assume they handled the basement toilet venting given the close proximity to the vent but I am not sure how to tell for sure? Any suggestions?
Thanks for any help or suggestions.
Regards,
Dennis
Regards,
Dennis
