Glenn Stowe
I recently did a bathroom reno in my 4-season cottage. While I was at it, I thought I'd swap out all the old 1/2 inch copper and PEX in the crawlspace with 3/4 PEX for the main supply lines to the bathroom fixtures. The thinking being I'd get the best water volume at the shower fixtures.
But..
The opposite seems to have happened. Water volume is poor, there are no strong flows coming from any of the shower fixtures.
I know normally the swap shouldn't make that much difference, but I am not on municipal supply, I'm on a pump that comes uphill quite a ways from a lake.
So my current theory is that the extra volume in the supply lines is too much for the pump to push and I should swap everything back to 1/2 inch to reduce the load/head. Between the hot and the cold there are probably 50-60 feet or so of 3/4 PEX in the system.
Before I try that, does this theory make any sense?
To add to the complexity, the pressure tank is also currently out of commission (blown membrane). While still in the system. But my understanding is that the only difference that makes is that the pump has to kick in more often. True?
But..
