2stupid2fixit
Active Member
The old 240 volt pump was at the end of 275 feet of 2 conductor wire on a double pole 20 amp breaker. No ground.
The new pump has two 120 volt legs and a ground.
I imagine to PROPERLY do the installation correctly, the wire from the house to the well casing needs to be replaced also so that there is a ground going back to the ground bus in the breaker panel.
I don't want to dig up and replace the cable that goes from the house to the well case.
So is it acceptable to tie the pump's ground to the metal well casing considering that the casing is made of metal and so it is essentially a really long grounding spike anyway?
Does anyone recommend that I change the standard Double pole 20 amp breaker to a GFCI version?
Am I over thinking this since the water in the well grounds all of it anyway?
