James23912
Finally connecting new wiring in house, I will probably see this situation in several as
Witch boxes, so thought I would ask here.
I have a 3 gang box for 3 switches in bath, one switch for vanity light, others for fan/light, so there are 3 wires for them as well as a hot line coming in and another line continuing the run, I know what to do with the black and white wires but am not sure on the grounds, my thinking is to connect the in and out lines together and attach each individual ground to the switch that corresponds to the fixtures, does this sound right? I don’t know if you need switch legs for ground wires.
IOW, attach the ground from the wire going to a fixture to the switch and then attach the other two grounds that are carrying the power
