froddan
- Messages
- 52
- Reaction score
- 0
- Points
- 0
I need to replace some 1 1/4" Galvanized pipe with 1 1/2" PVC because I will install a second lavatory sink.
In the picture you can see the scenario, and I'm trying to decide where I should cut the galv pipe and connect the PVC.
What would be the best/easiest option?
Underneath the wall, a Galv pipe probably 1 1/2" or 2" is going horizontally all the way to the main stack of 3" cast iron.
The pipe on the left is 1 1/4 and that is the section that needs to be replaced.
I would like to connect the PVC at the reducer bushing on the upper right, but don't know if I can get the existing galv pipe off without sawing it...it seems to be really really tight.
I also need to connect to the horizontal pipe below.
Any thought on what the best connection(s) would be?
Thank You!
Thank You!
