So, I don't know if it's advisable, but the IPC would let you vent everything via a single 1.5" dry vent for the double lavs. E.g. per the drawing below, where:
-Red is 3", Blue is 2", and Green is 1.5".
- Circles are vertical pipes at the floor level, i.e. the vented double lav drain, the shower and tub drains, the closet flange, and the stack
- I accidentally drew the drain running left-right on the page too low, so the closet flange is off center, but that's not intentional.
- The tub and shower trap arms are limited to 2" in drop, and hence a maximum length of 8', which is only possible if you get the slope at a perfect 1/4" per foot.
- I chose a 2" trap for the tub because a 1-1/2" trap would be limited to 1-1/2" of drop on the trap arm, and hence 6' of maximum length
- The branch drain must be 3" for the portion carrying the shower, tub, and 2 lavs, because it is wet venting the WC and over 4 DFU.
Cheers, Wayne
