ThereGoesPlanB
I'm just starting the process of remodeling my kitchen, partially spurred on by a dishwasher that stopped draining. While removing the dishwasher and it's drain tube, I was a bit perplexed at the existing plumbing. This first picture shows the drain tube entering the sink base cabinet and extending up above the drain:
Rather than go into the garbage disposal, there is a an open waste pipe that it's shoved down:
Here is a somewhat blurry picture of the rest of that waste pipe:
So that waste pipe exits through the back of the wall below the main sink waste pipe. I only have one drain pipe entering the crawlspace at this location, so presumably it's connected to the main sink drain in the wall.
So my questions:
1) Is this up to code? If not, are there issues with this arrangement besides code violation?
2) Do you see any reason why the original owners/builders didn't use the garbage disposal? I'm almost certain this arrangement was created when the house when the house was first built.
3) What should I do with this pipe when I replace the cabinets and put in the new dishwasher? Can I just cap it off at the wall and route the new drain pipe to the disposal?
So my questions:
