What bit and screws for Toilet Flange on Porcelain over wood subfloor?
LLPA
PA
My brand new toilet flange is sitting on top of 3/8" porcelain tile which is on top of 1 1/4" wood subfloor.
In order to screw flange to floor do I use diamond bit until I hit the wood and then switch to a regular bit?
And do I use stainless steel screws? Not Tapcons?
Yes, use a clearance hole sized tile or diamond bit just to get through the porcelain. Then select a pilot hole sized drill bit for the wood subfloor, and use a stainless wood/sheet metal screw at least 1-1/4" long, 1-1/2" would be slightly better.
Cheers, Wayne
Brass or SS screws. but really Tapcon are coated and might be considered non-corrosive.
Even the "coated" deck screws that are for pressure treated lumber are relatively non-corrosive like GRK brand.
Cheers, Wayne
Thanks! Picking up diamonds tip bit today.
Which scree size do you suggest? #10?
And be careful when drilling the tile that you do not blow through it into the wood and end up with an over sized hole in the wood.
Done, thank you!
No cracks...just took a long time drilling through porcelain with Harbor Freight diamond bits.
Did go faster once I switched to Milwaukee one.
