Wet Vent for Bathtub
Thomas K
Opelika, al
Hi, guys!
If you remember me, I was replacing cast iron piping in split level home. Well, I finally hired a licensed plumber to replumb it all for $1400. Looks like he did an excellent job, using wet venting for two bathroom groups. I am a little curious about the tub drain. He installed a 1.5" bushing into a 2" trap, but there is no sanitary tee and vent pipe at trap. 2" drain pipe continues down about 6' where it joins a 2" wet vent. Drain pipe is above the trap weir. Is wet-venting like this okay?
We had to move in because we sold house we were living in, and my camera is packed up somewhere.
Thanks for any replies!
Hi Thomas good to hear you moved in! is it dry walled and finished?. with IPC code you should be ok 6 foot from vent
Thomas K
Opelika, al
Hi Thomas good to hear you moved in! is it dry walled and finished?. with ipc code you should be ok 6 foot from vent
Drywall is in, but tub area still has to be cement-boarded and tiled. I hired someone for that as well. I will post photos when I can.
Thomas K
Opelika, al
That part's okay then. I did notice that he centered a Double San T between the two sinks of the bathroom vanity instead of using a Double Fixture Tee. Is this something that needs to be corrected?
double san tee I've never used one and don't see them used in plastic or on anything since I've been plumbing other than old work. whether its legal in your area (or mine for that matter) not sure . but I don't see it done , my guess is a couple lavs probably be ok but my house I'd change it if walls were open
Thomas K
Opelika, al
He eliminated use of the 4" stack. Plumbed in one more 1 1/2"" roof vent for total of three 1 1/2" vents. One 1 1/2" roof vent vents dual vanity, bathtub, and one toilet, in that order. Second vents one sink, a shower, and second toilet, in that order. Third vents washing machine alone. All drain pipes are 2" going into 3" main drain line.
That sounds good. I rarely plumb a single stack out the roof but on older homes it was common like how clean and simple it is, newer homes seem to be laid out with little concern for plumbing so whatever works and easy. 3 ,to 6 vents common around here. in our code it would take 2 ,2 inch and 1, 1 1/2 vent but I think its pretty well proven 2 inch really isn't necessary for a w/c .
Thomas K
Opelika, al
Thanks, Jeff! Only thing I did notice was he cut a 3" pipe through 2 x 10 floor joist about an inch and a half from edge of joist, which I'm sure doesn't meet code, but I know this has to be done at times. Any way to reinforce the joist? It is sistered.
wwhitney
Berkeley, CA
Was it sistered because of the oversized DWV hole (good), or was it already sistered because it has a larger than typical load on it (bad to put a DWV hole through a beam)?
Cheers, Wayne
Thomas K
Opelika, al
Cheers, Wayne
I sistered it to have level floor because of pointed joists. He did not cut a hole under the tub or washing machine. This was more in the general walkway of the bathroom.
Thomas K
Opelika, al
Here is a photo of the installed fitting for dual vanity sinks. I was wondering if that one is okay or if it should've been the fitting in the second photo. Finally uncovered my camera.
I think it'll be ok probably never have an issue. Ive never used the double santee . my house the walls were open, Id rework it unless I was really pressed for time. just my opinion I don't like it. wouldn't lose sleep on it though
Michael Young
North Carolina
need a nailplate for the hot water line. use of 1-1/2 regular 90 laid on the horizontal. should have used a long sweep. $1400 price. little dude didn't charge you enough. Work needs to be inspected
didn't mention the 1/4 bend for trap arms they use them commonly, legal or not. my code requires a sweep. 1400 price don't know what he did because Thomas K been working a lot repiping the the house. out here prices gotta be double or triple Alabama and some states
Michael Young
North Carolina
If the dude does good work and is reliable, sounds like you found a good dude that isn't too hard on the wallet
Thomas K
Opelika, al
I do think holes he drilled (3 1/2 inch in sistered 2 x 10) compromised joist, though. Other than that, plumbing was excellent. Isn't there some way to strengthen these holes? They are in middle of span.
Thomas K
Opelika, al
Here are more photos of some of the work that was done. In first and second images (1978 and 1979) toilet pipe and wet vent are shown. Pipe with blue tape in image 1979 is a stub out for future shower drain.
wwhitney
Berkeley, CA
Yes, you can and should reinforce the joists where the holes are either (a) bigger than 1/3 the joist depth) or (b) closer than 2" to the edge of the joist. There are various options, but if your job is being inspected, you might require an engineered solution. In which case a pre-engineered option like that at joistrepair.com would probably be the way to go. Otherwise, you can just do something similar to what you see there.
Cheers, Wayne
Thomas K
Opelika, al
Thought I'd show you guys some photos of how the shower/tub tile work's going.
