First post so hello to everyone and thanks in advance for any input.
I have a cottage/home in Northern Ontario which is about 5 years old. The well is 145 feet deep through granite rock. We could not afford to complete everything at the time of build and are now finishing up the details such as water treatment. My main issue is with water odor. This is what I have done.
about 2 years ago due to a severe Sulfur smell I replaced the sacrificial anode in the water heater which improved the odor significantly but not completely.
Just this past May 2017 due to appliances such as washer and dishwasher being installed I had a plumber install a sediment filter and water softener with iron removal system. water tests showed very high hardness and iron content.
For the first month or so any trace of odor seemed to disappear completely and the water is soft and as I expected. However, since about the middle of June the water has smelled awful but not like the sulfur smell before. It is just a raunchy swampy kind of smell. It is in both cold and hot water and is even noticeable running the garden hose. I put a couple tablespoons of bleach in the softener salt reservoir and ran a regeneration which seemed to help for a few days but then it was back the same.
We occupy the house most weekends and turn the water pump off when we are not there to guard against flooding in our absence.
My thoughts are maybe I also need a UV filter to kill any bacteria before it gets to the softener and hot water heater. I am guessing that even though harmless, some bacteria is thriving when the system is not being used regularly.
Any thoughts would be helpful?
