coldspring
Hello, I have a getaway property in the northern part of the country and for the next few yrs its summer use only. I had a well put in 65ft, water 35 ft down. I decided to skip the pitless until i build and use a well seal. My well guy who has been in the area may yrs and comes highly recomended wants to set the pump at 50ft come through the seal to a tee ,cap it and run the side leg to a check valve and on to the pressure tank. The cap on the tee will be used to drain it off back into the well for the winter. He wants to remove the valve from the pump to achive this. I had intended to put a tee and check valve down in the well at frost level with a bleeder to cover for the freeze. This system will only be used to fill water jugs and last but not least a shower. Will removing the valve on the pump instead of leaving it in and putting one at frost level do any damage to the pump . Not being a pro in the least, I am all ears and as i said need sound imput from those who know
