Well pump won't prime?
Rod M1
Michigan
The well is 30ft down with 20ft of water in it 1-1/4 pipe new point Goulds J7S jet pump. The pump whose tested last summer on another well and worked fine. The system will hold presser from the check valve threw the plumbing system don't think its a leak there. From the well point to the check valve there is a slit presser vacuum when removing pipe fitting on the well.
My question is what kind of vacuum should I be getting to draw the water up to the surface. If I put my hand over the pipe fitting while priming on the well I get some suction but its slight not like a shop vac more like something on a car.
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
The well is 30ft down with 20ft of water in it...
By my math, the water is 10 feet below the surface and a pump should have no trouble lifting 10 feet. Sand-point wells with a top-side check valve can be difficult to prime since the column of air has to move through the pump without losing prime.
Do note that jet pumps need water and pressure to pump so part of priming involves hold back as much of the water as possible while letting out the air.
WorthFlorida
Solutions
Orlando, Florida
Here is the priming instructions. You may already be following this procedure but as LLigetfa suggest, have to get the air out. Internally the jet can be clogged with a little rust or debris.
Rod M1
Michigan
The flustering thing is the pump should have no problem and I don't seem to have any leaks but something isn't right. Maybe it's air locked I will look at the priming.
LLigetfa
NW Ontario, Canada
Where is the check valve in relation to the pump? Best to place it as far away as possible from the pump.
What is on the discharge side of the pump that can help trap water yet let air bleed off?
A shop vac normally cannot lift water 10 ft.
Rod M1
Michigan
Didn't have the pump but it will be sitting on the block but should give you a general idea.
