The well is 30ft down with 20ft of water in it 1-1/4 pipe new point Goulds J7S jet pump. The pump whose tested last summer on another well and worked fine. The system will hold presser from the check valve threw the plumbing system don't think its a leak there. From the well point to the check valve there is a slit presser vacuum when removing pipe fitting on the well.
My question is what kind of vacuum should I be getting to draw the water up to the surface. If I put my hand over the pipe fitting while priming on the well I get some suction but its slight not like a shop vac more like something on a car.
