Muleskinner
Hi! New to the forum, glad to have found you folks. Seems like this might be the right place to ask some questions about what we're trying to do.
We have a piece of property on the olympic peninsula that we're building out ourselves and we're attempting to run our three wire well pump off of a generator and have it feed a water holding tank located a few feet from the well itself. All we want to do is run the well pump to fill the holding tank- no pressure tank because all our pressure will come from gravity from the 1100 gallon holding tank as the usage area is located about a hundred feet below the tank. Can anyone help with figuring out how to wire a three-wire 1/2 horsepower red lion well pump w/ a separate control box to a generator, without a pressure switch/tank, so that we can pump water up from the well into the holding tank? It's a 230 volt well pump, we have a plenty powerful generator (9000 watts, 240 volt) with a 4-prong outlet. We simply want to run the generator once in a while to fill the tank as needed, we don't need any kind of automatic on/off system or anything complicated. Would love some help with this!
