Well Pump Not Working???
livpl
Hello. This morning we woke up and had no water. When I went to the basement the fuse on the breaker box had tripped. Everytime it was reset, it would trip again. My husband took the cover off of the pressure regular box and when he would touch the two contacts together the breaker would trip everytime. Would this mean that the pump is bad? I went to Lowes to look at new pumps and it seems it would be much more inexpensive to replace ourselves. If we go this route and it is the problem, what is the process of replacing the pump.
Thanks in advance for any help. This is our first encounter with this issue.
R
Rancher
Guest
Yes the pump is probably bad, I assume this is an above ground jet pump that you can easily get to... we probably need more information, or a picture to help you replumb it. It will need to be primed after installation to work, the method of re-priming should be in the instructions.
Rancher
livpl
Well Pump Not Working?? Pump in well
Hi. Thanks for the response. The pump is actually down in the well.
R
Rancher
Guest
The reason I assumed it was above ground, is that you were going to replace it yourself, so tell us more about the well, pump etc. i.e. how deep is the submersible? Is it a 3 wire pump, i.e. does it have a control box that might have a bad capacitor, or relay.
Rancher
livpl
Details on Pump
Our well is ~300' deep. It is a 2 wire and does not have a control box.
Gary Slusser
That's all folks!
To know what pump you need, you should take the old one out of the well and duplicate it. That's if the pump is bad, it could be the cable causing the short.
You should electrically troubleshoot the problem before doing anything. Then pull the pump but... if you haven't done this before or seen it done, I suggest it may be a bit over your head. And if you have galvanized drop pipe, you need some heavy equipoment to lift it and hold it while you unscrew 20' sections. If you drop it down the well, you may need to drill a new well.
livpl
Details on Pump
Found out our well is 405" deep and takes a 2 wire 3 gpm pump. The company is saying it would be ~$1600 to replace. Is this a good price or are we being ripped? Not sure whether to go ahead and have someone do it or try it ourselves.
Speedbump
Active Member
Riverview, Fl.
You still don't know how deep the pump is set. But with a 3gpm pump, I would have to assume the well is a low yield well which means the pump is near the bottom. You would be better served to let them do it. They have the knowledge and equipment. You don't. If you drop the pump and all attached pipes from one little slip, your in a lot of trouble.
bob...
