Hi, apologies in advance from this newbie with zero knowledge of the subject! We have an old rural property with a well as our only water source. The property used to be a working farm and had big sheds of ducks and pigs. It is now being used as a two generation home, so 2 kitchens, 2 washing machines, 4 toilets. We may convert in a few years and add a unit to rent out or add a couple of guest rooms to rent out. Currently there is a big galvanised pressure tank, its 1000L so thats about 265 US gallons I think. It has a hole in it, on the seam, we cannot get it fixed so need to replace. I am getting contradictory advice from various sources. One says replace like with like and get a 1000L galvanised tank (no bladder) and others say get a steel bladder tank 500L is big enough. We are going to get a new pump sized to fit the tank.
Our water is very hard, it corrodes everything and has a high iron content and we get a lot of sediment.
I would really appreciate advice on which is best in this situation - type and size.
Thanks so much in advance.
