Radu Gafitanu
Hello,
I am new to this forum and I need help with (what is to me) an unusual problem.
This year I was opening the pool and I had to add some water. I dropped the garden hose in the pool like every other year. Shortly after that the pressure in the house dropped to almost nothing. Water was coming out of the hose in the pool but it wasn't the flow or pressure that I was used to.
The gauge was showing between 15 and 20 PSI. The pump was running but the noise was different. Before, the pump action had a continuous clicking noise (probably from the check valve), now it was a hissing. Turning the water off would bring the pressure back up. The cycle switch works between 40 and 60 PSI.
What is weird is that any other normal faucet or shower flow does not bring this behavior. Also if I attach the garden nozzle to the hose the pressure is back up. Of course if I open 3 faucets I get the same drop.
I have a Franklin 2 wire 1 phase 1 HP pump in the well. I checked the resistance and it is 3.4 ohms which appears to be correct for the motor and 300 ft. of wire. The current draw when the pump is running is 9 Amps which also appears to be correct.
The tank has about 38 PSI and it sounds empty at the top and full at the bottom.
When I turn off the hose (or the faucets) the pressure quickly gets up to about 40 PSI then in about 3 minutes to 60 PSI.
It appears that both the pump motor and the tank are OK. I am not sure about the check valve right before the switch.
Has anybody seen something like this?
Thank you.
Radu
Thank you.
Radu
