Silversaver
I have a Watts water reducing valve LF 25AUB S DU Z3 1 1/4 that need to be replace. Since the union fitting is already there so I save some money and order the replace unit without the fitting as LF 25AUB DU-LF-Z3. The description says No O Rings and No Gasket. I am wondering if I need to purchase the o rings or gasket before replacing the unit. I had replace it 10 years ago and I order the same unit came with o ring pre installed. I recall I trash the union fitting since I am using the old fittings. I do not recall because it is very long time on how the o ring or gasket looks or needs.
I am wondering what kind of o ring or gasket do I need for the union fitting.
Thank you
Thank you
