Sorry I'm not sure what to call it for the thread title....
Is there an easier way to determine if my cold water line is somehow connected to my got water line without tearing apart my walls???
Here's my dilemma.
In replacing my water heater I discovered a pex connector leak in my hot water line. So I disconnected everything again drained the hot water line (so I believe) and left the cold water active so the family can still use water. Shutoff valve on the cold to the water heater is closed so that part is obviously not flowing.
So both 3/4 water lines that would connect to the water heater are dangling there. 24 hours later, the hot water line is still dripping even with all the faucets on the house open to the hot side to get it out.
Here's the weird part. If I run cold water in the house which is still active, water will aggressively flow from the hot water line into a bucket I have on the floor even though technically it's not connected to any water input! Its not a full heavy flow but it's like it's collecting somewhere still. Totally perplexing.
Secondly, the 2 handled bathtub and shower in the master bedroom should still have at least cold water active to it at least but both those handles offer no water. Where's the cold????
I was trying to be nice and give the family water while I worked on the hot leak but got frustrated and just turned off the well. Forget it.
But I'm still concerned about the connections.
Where is this water still coming from in my hot line???
Would the builder have a plumbing schematic of my house? Its 15 years old.
Here's my dilemma.
