Pktaske
So I have 2 bathroom ranch on well. Pressure tank and above ground pump are in utility room on one end of the house. Bathrooms are on far end of the house. On slab and hot and cold water lines run underneath (in slab I presume). I have a 1.0 Filox filter set up 4 feet downline of pump that has been in service since 2007. Very high iron. 20ppm at least but no hardness.
Up until 2 weeks ago, everything was good. However, first my cold water in one bathroom started trickling out. Toilet also taking forever to fill. Hot water was sort of ok but now is also slow. Now water is starting to slow in other bathroom. Sink in kitchen ok so far (its midway between pump/tank and bathrooms).
Whats the best way to check this? I assume there is clog gathering in the pipe at the other end of the house? Air pocket? How do I pinpoint the problem?
I rebuilt the Fleck head about a month ago and it seemed to work ok until also 2 weeks ago. Now not backwashing - just also a trickle coming out of backwash drain (normally shoots out gallons of dark red water). Would the Filox media be escaping and flowing down the other end of the house? Wouldn't I see some evidence of media coming out of faucet/toilet?
Thanks for any help....
(I turned the stainless bypass valve to bypass the iron filter and water still trickled at bathroom. I then pulled the valve off and opened it up over a 5 gallon bucket. Water flowed with heavy pressure so the well/tank are working).
