I'm looking to fully repair or replace my system.
I bought a family owned house a few months ago with an unmaintained water filtration system. The system is an old CSI two tank system with what appears to be either H2O2 or Chlorine solution tank. The tank isn't attached to anything and the somewhat working motor has rusted.
I tested the water at the filter as that's the only access to the system. Kar reported the following:
Arsenic - 0.003 mg/l
Barium - 0.06 mg/l
Calcium - 137 mg/l
Iron - 0.14 mg/l
Lead - 0.002 mg/l
Magnesium - 52.6 mg/l
Manganese - 0.188 mg/l
Potassium - 2.5 mg/l
Silicon - 8.9 mg/l
Sodium - 42.0 mg/l
Strontium - 0.6 mg/l
Sulfur - 27.0 mg/l
Alkalinity - 378 mg/l
Bicarbonate - 378 mg/l
Bromide - .12 mg/l
Carbonate - .45 mg/l
The house has two HW. The newer, <10 yr, has a horrible sulfur smell in the kitchen. The older, 20> yr, one has a heavy metal smell when your taking a shower.
The sulfur smell goes away for a month or two if a shock the well with Chlorine. So I'm guessing sulfur bacteria.
The well is 155' cased fully at 4.5". The rock is Blue Shale till the bottom 40' which is in Sandstone. The well tested at 8 gph when drilled in the early 80s.
Barium - 0.06 mg/l
Calcium - 137 mg/l
Iron - 0.14 mg/l
Lead - 0.002 mg/l
Silicon - 8.9 mg/l
Sodium - 42.0 mg/l
Sulfur - 27.0 mg/l
Bromide - .12 mg/l
