First off, I just want to call out that I've found this an incredibly useful forum and really wanted to take a moment to thank everyone here for that. Now that I've buttered everyone up, hopefully you can forgive the very long post.
I have a 6" diameter low yield well - ~2 GPM specifically - at ~300 feet in hard rock. Pretty disappointing all around but I'm going to make it work with as minimal a lifestyle shift as possible. The bore holds maybe 100-150 gallons of water all told.
Since I have a few acres and do actually expect to have a bit of a yard as well as a normal family of 3 water-usage lifestyle, I know I'm going to need a cistern. I have a convenient location in the basement where I can get up to about 2000 gallons stored before it starts becoming a bit of a hassle. This would be a homemade water tank ~11' x 3' x 8' and using a potable water liner - something like these. I'd build the tank out of steel framing and plywood attached to the concrete with steel studs epoxied into place.
My plan is for the well pump to be hooked up to a float valve in the cistern to try and keep it topped off at all times. I was looking at these specifically. The well pump would run through a Pump Saver Plus or such to protect from running dry. The water from the well runs through some spindown sediment filters until it gets to the cistern itself. I don't really have a sediment issue but this is very cheap insurance if you look at these things over the long haul.
In the cistern would be a second pump. I was thinking a submersible with cooling shroud. This in turn would be hooked through another float switch to prevent running when the water is too low in the cistern. This would run to a typical cycle stop valve setup with the exception being a larger pressure tank (20 gallon Welltrol) just to avoid turning on the pump for simple toilet flushing and hand washing. From there, the water is broken up a couple ways: toilet tanks and such get direct water, no more filtering. Anything else runs through the appropriate filters until it goes to the destination. I'm not sure if I need to do any filtering at all as we are still developing the well but I don't want to be a position where I cant.
So now the questions:
1) Ideally the well pump would run from full well to empty in one shot, not cycling at all. This could be done with a simple "time since last ran" calculation combined with a "once running, stay running for X amount of time". I'd still want a catch all "run dry" protector in there as well but is there a product that does this? It seems a lot cleaner for a cistern system like mine?
2) What is a good choice for the in-cistern pump. It seems a straight up submersible well pump with a cooling shroud would be a solid choice? But what GPM is needed for a typical house? Sizing this has proven a lot more fuzzy than I expected.
3) In practice, what size should the cistern actually be? In theory, the well can put out 2880 gallons a day but Id never count on it. It feels like making a tank larger than can be refilled in a single day (even with abnormally heavy usage) is a bad idea but I can't say why. Sadly, as this is a new property and new house, I really have no baseline for water usage other than a small family of three and we are not terribly wasteful.
4) Is it better to use a float valve and a pressure switch than a float switch for the well pump? Long term reliability is a key concern of mine and if this approach is more reliable over time than I'm all for it.
Thanks in advance for any help!
-Mike
-Mike
