I bought my current home about 18-20 months ago in an area with harder water. The home came with a Safeway water softener even though our specific area isn’t that bad but other areas of the city are apparently.
When I first bought the house I read up on water softeners and checked the salt reservoir and it was low with water above the existing pellets. I filled it up with the remaining 1/3 to 1/2 a bag that the previous homeowner left.
About 3 months later it was almost depleted again and I figured ok I’ll go through 3-4 bags a year so I went to the store and bought 4 bags. Put an entire bag in and fast forward over a year and there’s still quite a bit of salt left in the bottom (above water line). I checked to make sure it wasn’t a salt buildup/island or dam and it isn’t.
My concern is perhaps the softener isn’t doing anything. It cycles through the current time, capacity, capacity remaining, last regen time. It shows the last regen time over a year ago and the clock is currently set correctly.
I was able to get into the menu pages and they read as follows:
System Language: English
Valve Operation: Softner
Regen Mode: Meter Delayed
Regeneration Time: 2am
Capacity Calc: Automatic
Resin Volume: 1.00 FT3
Salt Setting: 7.0lbs/cf3
Refill Flowrate: .61GPM
Unit Capacity: 30,000 grains
Reserve Capacity: 75gal per person
Capacity: 2,427 gal
It’s a Safeway Model with dual black tanks but can’t find a model anywhere on the tank.
I’ve noticed the Current GPM shows zero even with water running in the house.
Are these units smart enough to sample the water and only add when necessary? What should/can I do to make sure it’s operating before calling in a professional?
Capacity: 2,427 gal
