ciws14
- Messages
- 8
- Reaction score
- 0
- Points
- 1
I have a 5 year old Genesis Premier Softener with fine mesh resin and it was sized from a water sample I had sent in to the vendor. It is rated at 36,000 grain and worked great up until about a year ago. I noticed the water was always hard. I was barely using any salt. Less than a bag every 2-3 months. I knew there was an issue. I did a couple of manual regens with some softener "cleaner" chemicals and things seemed to be a little better. The water would be hard again, so per the vendor, I increased the number of people in the settings and set hardness to 20 grains. The other settings are Refill Time 7.0 minutes, Salt setting "standard", etc. There is typically a couple of inches of water at the bottom of the brine tank at all times. I do notice that when I add water to the brine tank (3-4 gallons) my water stays softer longer. So I have been adding water when I notice a regen on my way out the door in the morning. I will add water to the brine tank later than evening.
Any ideas on what could be going on?
Thank you!
Thank you!
