I've got a new water softener with a Fleck 5810SXT valve that is not working. It's almost like it's in bypass mode still. I've watched the Brine draw and brine fill appear to be working properly. I've watched it drain and re-fill. What could be causing literally no impact?
Hach hardness test at well: 32GPG
Hach hardness test at faucet: 32GPG
Fleck 5810SXT Settings:
DF = Gal ; Units
VT = 5810 ; Valve type
RF = dF2b ; Downflow, Double Backwash
CT = Fd ; Meter Delayed regen trigger
C = 49.5 ; capacity in 1000 grains
H = 34 ; Hardness grains after comp factor
RS = cr ; Cr = base reserve on recent experience
DO = 30 ; Day Override (typ 30 if no iron/Mn)
RT = 2:00 ; Regen time (default 2 AM)
B1 = 5 ; Backwash 1 (minutes) [3...10]
Bd = 60 ; Brine draw minutes
B2 = 4 ; Backwash 2 (minutes)[3...10]
RR = 6 ; Rapid Rinse minutes
BF = 23 ; Brine fill minutes
FM = t1.2 (usual) ; t1.2 is default flow meter
RE = OFF ; Relay
VR = OFF ; ?
DF = Gal ; Units
RE = OFF ; Relay
VR = OFF ; ?
