Hello All,
Thank you for helping me choose a Fleck 5800SXT for my new home. The softener is installed and I have a question regarding the drain.
Is it wise to drain your softener to the foundation perimeter drainage system? I think about the impact of salt on concrete so this worries me.
We have a walkout basement so the contractor didn't install a pump in the sump pit stating it would naturally drain which does seem to be the case given this wet fall and no moisture in the basement. I believe the sump pit connects to form-a-drain footing forms for foundation drainage. They have the water softener draining to the sump pit which I think will fill up and dissipate via the form-a-drain system.
I have a septic system so that sounds like 50/50 on whether it is wise to discharge to the septic system. Thanks.
Chris
Chris
