Water just warm, not hot
Higgledy
quote; Here is a link to a water heater problem nearly exactly like mine. He's final solution was to replace the water heater.
A plumber bought a new heater to replace for a customer and then brought it back because it was not heating the water. I told him he had a broken pipe, but he refused to believe me. The supply house did NOT refund his money, but told him they would return the heater to the manufacturer and if they said it was defective and gave them an allowance then he would get his refund. HE came back later, after installing the second heater and said it was a leak.
As soon as you said the upper element was never satisfied, THAT made a leak the only possibility. As far a "high watt density" elements are concerned, they are cheap but almost useless. I have had them fail within weeks of installation. Plus, I never use 3800 watt elements, only 4500 watt ones. And they are either "low watt density" or "lifetime" Ni-Chrome elements. 3800 watt elements are advertised as "energy saving" that only means that they use less power per hour, however, that also means that they have to run longer to heat the water.
A "good" plumber would have detected that problem in a few minutes, WITHOUT replacing all the heater's components which were probably NOT defective.
Thanks. My wife does not think my plumber is good either. In the past, I've hired him to remodel a bathroom. His work is neat and I've had no problems with shady workmanship, etc. I guess he needs to beef-up his diagnostic skills. The other thing is that it is difficult to find a good plumber, especially when you really need a plumber. I assume a plumber is more likely to get to your house that day if you have history with that plumber. Is that illogical thinking?
BTW, the plumber replaced the 3800 Watt element with 4500 Watt element, it was a high watt density, but he did not know that we had hard water. He told me that water heaters he services on the other side of my county he always uses low watt density elements because that side of the county is know for hard water. I never knew my water is hard either till this experience. Now, I know.
I've learned in life that a good plumber, a good electrician, and a good lawyer are all worth the money they charge. Thanks for the advice.
Phil
If there is a "high watt density" for the upper element and a "low watt density" for the bottom, you will be OKAY. But, if the bottom one is HWD, then keep your old elements because you will need them.
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
quote; Even the pro's sometimes get it wrong on the first try. Hopefully they go good for it.
I am glad you said "sometimes" because it should be a very rare occurance for a "good plumber", and usually happens when they have multiple problems and one of them is "masking" some of the others.
