Charlie B
Thanks for taking my question.
I have a cabin in southern Vermont that is pretty much seasonal, but I set it up for 4 season use after much effort. The cabin is on piers and the well is 30 feet from the cabin.
The well line is buried until it rises above the surface five feet under the cabin. Then it runs at a constant angle 30 feet to the other side of cabin. The pipe rises to thru the floor and connects to a blue expansion tank (I believe) and 10 gallon water heater. The exposed well pipe has commercial grade heat cable that extends from inside cabin to two feet below grade.
the issue:
When I purchased the cabin, I was told that the well had no check valve. This allowed water to drain back into the well from the lines in order to prevent standing water from freezing in the lines in winter. It made sense to me. Yet I’m not sure how this was done.
The drain back of water works great. I just turn pump off and open faucets and water drains. No problem there. The issue is when the pump is turned on or activated. I get lots of air in the pipes.
I really haven’t messed around with anything to explore the problem. I did several years ago, release a pressure valve on my blue air tank, but did nothing else.
I see no snifter or shearer valve on the lines. I really didn’t look too closely at the blue tank
What kind of set up do I have and what can I do about the large amounts of air, if anything?.
the issue:
