Washing machine drain tie-in placement, 5' rule?
Suceress
Active Member
LA
I'm in Louisiana but in 2016 the state code was abandoned and reverted to IPC 2012. I was drawing up plans for a remodel and I was advised to have the washing machine drain tie in at least 5' away from other fixtures to avoid suds bubbling up in them.
1. Is this a common problem and is there anything in the plumbing code to indicate this rule?
2. Can the washing machine tie-in (to main soil pipe) be upstream of a tub and toilet?
3. Would suds from the washing machine bubbling up in the tub cause any problems or damage anything on the tub or its plumbing?
I have a setup where the order of flow would be washing machine, tub, and then the line carrying both toilet and lav waste. The tub is actually the closest fixture to the main soil pipe but due to the proximity of the drain to the exterior wall and placement of the main vent, I would need to run the trap downstream of the cleanout at the start of the soil pipe. This would place it so the washing machine would tie in first.
  1. no
  2. yes. Proper venting required
  3. no
You will use 2 inch pipe for your standpipe. If you get suds coming out, you are using the wrong detergent and/or way too much detergent.
I am not a plumber.
Suceress
Active Member
LA
Thanks for the response. I didn't think there was anything in the code about it, but wanted to be sure in case I had missed it (bc I looked at the code and searched for anything to do with laundry / washing machines & standpipes).
I wonder if the cleanout has to be above the flood level (I want to have one on the vent pipe going down to the drain for the vertical run and will have another cleanout at the end of the main soil pipe where it runs horizontal)
